Results 1 to 10 of 10
Thread: 2001 gmc z71 5.3 w ls2 cam need info
    Jul 2014
    I am new to this site and would like to start by saying thanks in advance for any help
    which I may receive!
    I built a 5.3 for my 01 z71
    I put the flat top pistons in it and a set of 243 casting heads
    I also put a ls2 cam and the ls2 front cover with sensor on it I changed the wiring
    as ness and now I'm setting a p0342 cam sensor low voltage code I've never had any
    issues with the cam sensor wiring before now
    please help as I'm a little confused 01 is a 12v system and the ls2 sensor is a 5v
    setup what can I do?
    Pittsburgh, PA
    Did you swap the cam wires when you moved sensor to front
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Jul 2014
    yes it was setting a p0343 high voltage code
    now I'm getting the 342
    2001 is a 12v system the new sensor works on a 5v setup
    is this my issue?
    Jul 2014
    so I called Lingenfelter and spoke to a tech about my problem! I used a newer one bolt cam and sprocket
    which was a mistake its a 4x sampling a 3 bolt cam and sprocket is a 2x and no one makes a 2x one bolt sprocket
    at this time so I either live with it or I have to change the cam and sprocket
    does anyone have a ls2 stock cam that is a three bolt setup? I'm on a strick budget expecially since
    I'm a $1000.00 in to this motor already
    Pittsburgh, PA
    Ls2 cam sprocket is all you need for a Gen3 pcm. its the 1 x setup and is a 3 bolt setup
    412 Motorsports
    Jul 2014
    yea I made the mistake of using a one bolt cam
    my dumbass mistake just didn't realize the difference!
    no extra money as of now so I guess im just stuck with it for a while!
    I just looked at your build
    Very nice!!!!!
    Pittsburgh, PA
    which build the 02 or the 10?
    or swap to a ls6 cam and call it a day once you find cash
    412 Motorsports
    Jul 2014
    the 02
    Im thinking about taking a three bolt sprocket and drilling it out
    then welding up the three holes
    Jul 2014
    just ordered a new ls2 three bolt cam and sprocket
    hope I can put it in tomorrow or wed afternoon
    Jul 2014
    new three bolt cam installed with 1x gear
    truck was tuned yesterday and runs great we deleted the egr, the evap, and the rear o2's since I don't have cats
    truck ran a 13.9 in 1/4 and was showing 105 mph on the computer
    we ran her up to 130 but developed a vibration
    she cracked a ujoint on the launch
    im very happy with the results since this is my dd and I was looking for power, good mpg, and still have low end torque
