Results 1 to 10 of 13
Thread: need help asap DBW-DBC conversion
    Aug 2013
    Clarksville, tn
    ok so ive looked and read all over the net and lt1swap, either im not understanding or just totally confused. Im tryin to convert my dbw to dbc. reason is because when i bought motor the dbw was takin off the intake and i didnt get the pedal or tac. the guy i bought it fromfelt bad because someone had jacked my throttle body pedal and tac so he lowered the price to 400 and gave me a dbc TB. so now im tryin to figure out how in the world to convert it. I have the 12200411 pcm red and blue plugs so i know that pcm can be flashed for dbc. I just need to understand how to plug my dbw harness to the dbc TB. something about tps to oil pressure, or 02 sensors and thats where i get confused. pictures, diagrams, anything to help me figure this out would be greatly appreciated.
    May 2007
    Oak Forest, Illinois
    Connector C1 is Blue and C2 is Red.
    C1-8 Gray is TPS 5 Volt Reference.
    C1-60 Blk is TPS Low Reference.
    C2-24 Dk.Blu is TPS Signal.
    C2-76 Lt.Grn/Wht is IAC Coil "B" High.
    C2-77 Lt.Grn/Blk is IAC Coil "B" Low.
    C2-78 Lt.Blu/Blk is IAC Coil "A" Low.
    C2-79 Lt.Blu/Wht is IAC Coil "A" High.
    Jeff
    If you're swapping this into an 03+ truck, I'm going to stop you right now.
    Aug 2013
    Clarksville, tn
    The engine is goin in a 94 c1500. Its an 01-02 engine.
    Then it should have had a dbc to start with
    Aug 2013
    Clarksville, tn
    It came out of a Tahoe, it was the higher end one fully loaded it has dbw. I'm really not makin this stuff up lol. I know my pcm works I looked it up on lt1 swap its a 411 computer and I compared computer boards so I know that it will work and need flash I just want to know how to convert it.
