What would be the best rear shocks to use that would help me out in the track and street because i don't have a c-notch n it hits like crazy!
4.8 FBO-PULLEY 228/228 CAM 4.10 GEARS TUNED BY NELSON...JUST CRUSUIN SAN ANTONIO!
How much of a budget you got? Rancho RS9000s are great unless you want to step to like a QA1 or something along those lines.
how low is the drop, what drop and what shocks are currently on the truck?
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
4/6 without a notch?! I'm on a 2/4 and bang the frame constantly. You sir need a notch first. And consider some shock extenders, or even completely remounting the shocks so they're vertical.
Unless you have a 07+ I don't think they need a notch for a 6" drop
Shocks wont stop it from hitting. U need a notch first. Theres got to be a write up on how to install them floating around here. I have a nnbs on 7" rear drop and its rare if it hits.
Best ET 11.54@114 w 1.52 60ft
Raceweight 4905 lbs.
i have a classic nbs, with monomax shocks all around, and it would on hit if i had 200+lbs or hit a dip. but invest in a notch. check every truck forum you can someones got one cheap
