Hey guys Im doing a motor swap in my buddy's TBSS. He had oil starvation and destroyed the LS2. He had LME build him a 416 LS3 stroker and it dynoed at 607fwhp. I figured a 340 would be enough pump for him. I plan on running a drop in 340 with a bulkhead fitting on the bucket hat, then -8 to the rails to a regulator then use the factory feed as return. Does anybody know the part number for the correct 340? Also what has to be modified in the bucket to make it work correctly, as far as cutting and what not. Thanks!!
