From the moment I got my wiring harness hooked up ( I got the truck and the Transam harness grafted by the guy in Erie, PA ) this engine has purred like a kitten but I couldn't immediately hook up the oxygen sensors because of clearance problems . I was told this would be ok and that it was safer for the engine to run too rich than too lean . Today I went down to the exhaust shop and had them make the necessary adjustments and install an O2 bung in a place that I could get the sensor to clear the frame .This is only until I get my headers . But as soon as I hooked up the 2 front ones and installed the simulators for the two rear ones the truck refused to run right . It would buck in drive and then die . I would be able to restart it and it would ,but hesitantly so . It seemed to idle alright in park , though . I disconnected the two front ones and it returned to normal operation . I've been told that I'm probably only running at 2/3 to 3/4 of the potential HP of this engine like this and , obviously , I don't want to be running around with no forward O2 sensors sending a signal to the computer . I 'd really appreciate some input on this . Thanks guys .![]()
