Results 1 to 10 of 10
Thread: ignition off,truck sputters
    what could cause this?idling fine,turn the key ignition off truck sputters twice before actually turning off. ses light is on im about to go hook up the obd and see whats up...just thought ide get a heads up here.
    leaking fuel regulater or leaking fuel injector. Gotta have fuel to sputter. Ignition source is nothing more than residual heat and compression.
    i recently removed the zex n20 kit..i put the valve back in the fiel rail but i lost the damm plastic cap:/ dont know if that would cause it and well i removed the tr6s and put back the delcos....ill go over look it.
    casey23 Guest
    Like stock delco plugs !!??? Can I Ask why on nitrous that's no good .. Maybe fuel solonoid I leaking on the zex kit
    He pulled the kit off Casey, that's why the stock plugs are back in it.
    casey23 Guest
    Thanks !!! I am driving and reading on my phone so I didn't catch all that !! I hate stock plugs either way and I think is a nightmare if the motor has. Big cam with a good tune and then go back to stock plugs ... Sorry I will watch the road Now and tr6. In everything I do
    damm so u think i should stick with the tr6s even n/a?yea i put back the iridiums. btw i went back and tightened the valve on the rail it turned 1 full turn and well the light went away and it quit sputtering believe it or not...thanks for the input
    I run TR6's in both my trucks NA.
    Dec 2008
    san antonio TX
    i use the ac delco plugs, they work good for, then again my truck is stock
    +1
    how rich is your idle?
