Results 1 to 10 of 11
Thread: Need help with swap...plz...
    May 2010
    Im swapping an 05 lq4/ 4l80 in2 my 94 gmc ecsb and was wondering wud am i supposed 2 do about the ac? i know of moving the bracket? or basically wud am i supposed 2do about the ac? i have no clue and need sum advice plz....thx 4 reading...
    well you'll probably want to install the engine as far back as possible, so you can't notch the frame; hotrodlane.cc has a conversion kit for it, or others will suggest another a/c bracket they are using, i can't think of the guy/shop who makes them.
    May 2010
    wut about currentperformance.com for the ac bracket and lines???
    Yep, Notching the frame isn't the best idea. Mine was like that, and the a/c lines just kept snapping anyways. Plus the condenser and a/c compressor don't really like each other to much and always freeze up after being turned on to long.
    May 2010
    well i called street and performance and they wer telling me 2basically change out my ac system???does ne1 hav ne ideas on how i can use my ac with this 6.0...and where i can get the parts for this?
    get the JoshPowers bracket and keep your stock stuff.
    May 2010
    is this bracket on s&p or where at?
    Orono, ME
    Quote Originally Posted by La Ricky Bobby View Post
    A quick search would have yielded you the following thread... http://www.ls1truck.com/forums/racer...p-spacers.html
    Look at post #3 and thank RedHeartbeat.
    2012 Honda Civic Si - DD
    May 2010
    oh ok thx redheartbeat i need 2do a lil mor research next time.and thx 4pointing that out 2me bartjo.... ill email him here in just a lil bit...
    Orono, ME
    Not a problem, good luck with the swap... Post some when you get a minute, I'm a die hard OBS fan.
