Results 1 to 10 of 25
Thread: 6.0 installed
    6.0 installed
    Just a quick pic, the 6.0 is in the truck!
    ff_jeff Guest
    had to squint to see, and it appears to be gray blob on a red brick.
    Fixed
    Are you using the York compressor for an airbag setup? Clean firewall, for sure.
    Yes the 210 is for the air ride, and thanks for the comment about the firewall, I shaved everything extra that I won't use anymore.
    ff_jeff Guest
    man thats very clean. Good work!!!
    Gramercy
    thats so sick dude! i cant wait to see it finished.
    i like the firewall too. if i ever get a chance for a 5.3/60E s10 ill have to do that.
    2008 GMC CCSB 6.2/6L80e swap
    GA
    that 210 is a power robber. made my old truck a slug.
    04 5.3
    224/224 .566 .566 114
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    Aug 2009
    Port Arthur, TX
    Any more pics? Are you using the truck pan? I am putting the 6.0 in my bagged and bodied crew cab. Looks good by the way.
    Thanks man, I am using the F-body oil pan, it's great, when I am layed out there are 2 inches of clearance between the bottom of the pan, and the ground. and the pan clears the crossmember with ease. I don't have any more pics right now, but the truck is a crew cab stepside, or will be when assembled. I really like your CC dually, it's got to be a crew cab for me, even my DD is a 94 CC long bed.
