Results 1 to 10 of 10
Thread: KB Racing Intercooled Kit MP76
    Butler Ky
    up for grabs is my KB racing front mount turbo kit.. everything has less than 500 miles on it..
    Mp 76mm with .96 ar
    Tial 50mm BOV
    Tial 38mm WG 10psi spring
    3.5 downpipe with wideband bung
    Braided oil feed line and oil feed block
    10an drain line
    Large intercooler that fits between the frame rails
    2.5 intercooler piping before intercooler and 3in after.
    All silicone couplers are expensive and are the good clamps.
    Mics fittings and reference lines.
    All the hot parts are wrapped
    3500 obo
    76mm Front Mount, Yank PT3200, 6.0, Built 80E, Isky 215/215, Devils Own, Nitrous Express
    good looking kit. Pics of the intercooler and other small parts that will come with it?
    southside VA
    good price,good luck with the sale
    Butler Ky
    yea im goin to be taking the intercooler off the truck tom. so i should be able to get some pics up then,
    thanks
    -Nate
    Butler Ky
    thanks man i spent quite a bit of time grinding and sanding to make all every weld unnoticeable on the intercooler setup.
    -Nate
    Butler Ky
    Bump
    -Nate
    Feb 2008
    Arizona
    so, is it a complete setup? you where using it on a 5.3L right? how did it work? any rwhp numbers?
    interested
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Butler Ky
    yes the kit is complete as if u were to by it directly from Kyle.
    i had it with a 6.0 but no hp #'s because i decided to get rid of the truck right after i finished the 80e swap so i never took it to get in tuned. I have never even drove the truck more than a mile. i just said 500 miles because it has some ilde time and moving the truck in and out of the garage.
    -Nate
    Jul 2009
    is this still up for sale?
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    Butler Ky
    sorry it sold
    -Nate
