I have a 4.8 shortblock gen IV
I've seen the 5.3 and if im not mistaken they share the same bore - the difference is the stroke.
in order 2 convert it to 5.3 would i only need to change 2 shorter rod and longer crank.?
gen IV 4.8's/5.3 share the same flat top pistons..
why not just get a 6.0
all u need is the 5.3 crank with the right reluctor wheel for your aplication and the 5.3 rods
2014 Xsport- 3.5 Eco boost
412 Motorsports
Little mixed up, the HO 5.3's had the flat tops and were aluminium. The VHO's are the same a 2wd SS
to answer the question, yes a crank and rods would bring you to a 5.3L displacement, but if you bored the 4.8L out to 3.905'' and kep the stroke, you could build a high revving 327, which would be great with heads and a cam that had a high rpm range powerband
www.tjc.edu
