Results 1 to 8 of 8
Thread: 01 Denali Grill and headlights on....
    Oct 2003
    A 01 1500 HD
    What has to happen? Is it a direct bolt up or do I need to change the front bumper too?
    Im getting a 01 GMC 1500HD CC 4x4 6.0L and i want to put the Denali front end on it if its not to much trouble.
    Also Allen do you have some sort of towing tune where I will get more ponys and torque and still be able to tow with no problem?
    I am considering a LS6 intake on it and maybe a ZO6 cam
    Anybody know if the LS6 heads are that much better over the 6.0L stock?
    Thanks for the help
    http://www.danasoft.com/sig/bsnuggs.jpg
    2001 GMC 1500HD SLT 4X4 CCSB 6.0L
    Mac Performance Intake, 05 E-Fans, Magnaflow Catback, Pacesetter LTs w/ Custom "ORY", Comp Cams 210/210 555/555 112 lsa, Comp Cams 918's, Hardened Pushrods, HP Tuners, BB Thermostat mod, TBBP, EGR Delete.
    Not EVERYONE can be a Louisianaian, it's an art form and a gift from God!!
    Treat every situation like a dog; If you cant eat it or screw it-- Piss on it and walk away
    Aug 2004
    From everything that i have seen the only advantage of the ls6 intake on our trucks is it gives you more room. The ls6 intake is good if you are going to be spinning you engine out past 6500 rpm. I dont thing you will be. As far as heads go, I would say for the price that you are going to pay for heads dont. Go forced induction. You mentioned about pulling, if you are planning on pulling much then you need you hp and tq down low. Ls6 heads and intake move your hp and tq up high. However forced induction works great for towing. There are a couple of quys on here running the new sts turbo kit on there 1500hd. They use them for towing.. Look for Jerry2500 and Bud8Fan if you have questions about it. As far as tuning goes, get aholod of Allen at Nelson Performance he will hook you up with what you need. Either way good luck and dont hesitate to post any questions.
    04 Sierra Denali
    Blown,Cam'd,stall'd etc.
    The LS6 heads are good for towing if you're not going turbo because you get more compression. The moving the power curve up to a higher rpm is due to the cam, not the heads. The right cam with the LS6 heads will make one hell of a stump puller. Be prepared to pay a righteous price for a set of LS6 heads though. I haven't seen a complete set of used LS6 heads sell for less that $800 and I troll many vette websites watching for them.
    Oct 2003
    How about the headlights? anybody know if just the headlights are a direct swap or does the whole front end need to be swapped?
    Nov 2004
    Well, on a GMC yes, they are a direct swap, dimensionaly the same, my buddy has them on his 02 HD, and they are sweet, but i am hesitant to spend 300 on a set of headlights, and have heard stories about aftermarket sets being junk.
    Oct 2003
    Well I wouldnt buy anything but the factory lights. Im not one to buy aftermarket stuff like that if I can get factory.
    Yea its a lil bit more but its worth it in the long run
    Thanks for the info man Its been great help
    I think i can get the stockers for about $120 ea.
    Oct 2003
    Houston
    My buddy purchased some aftermarket projector lights and after six months or so the lenses turned a hazey yellow color. Looked real nasty considering he paid almost $400 when the first came out. You can't beat stock parts!!
    99 Pewter SCSB
    DJM 4/6 drop, Hotchkis front/reat swaybars,Hypertech power programer, milled & built heads, Accel wires, distributer,coil, Mass Air Flow Sensor(mti motor sports, Granatelli),Dynomax UltraFlow Stainless, 17x8.5 Eagle Alloys, Escalade door handles, Suburban front grille, with clear corners and billet bowtie,Street Scene mirrors, Cowl Hood
    No crap. The lights that came with my SAP brand Escalade kit are cheap junk. They won't adjust with the adjusters, you have to remove the light and adjust it and put them back in. The adjusters keep popping out of their holders and makes the lights bounce around.
