Results 1 to 10 of 21
Thread: Tire question
    Tire question
    I was looking at tires to be mounted to a 17" or 18" wheel that is probably 7-8" in diameter. The ET Street Radials I am looking at say that the approved wheel width for the 28x11.5x18 is like 9.5-11.5", and then the approved wheel width for another size (27x10.5x18) of the same style tires is 9.0-10.0". If I use the first style, will they even fit onto my rim? I mean I am running 28x11.5 slicks on my stock 16" wheels.. would I have a problem with the other ones?
    personally i would stay with some stock rims, any after market rim besides custom made are gonna weigh a ton vs. stocks. but if weight isnt a problem then go as you plan. either way you should be fine on what you choose, personally i would look into a 26" tall tire since youre turboed and your gains are up top not as much as down low
    Simple: 408 on steroids!
    single digits coming soon!
    Racoon Twp., PA
    they just will be a lil balloony
    2013 CC 5.3
    81 C10 LS1 project
    I thought a bigger diameter tire, would be more beneficial with up top mph then a smaller diameter?
    Quote Originally Posted by tanz45 View Post
    So a tire recomennded for a 9.5-10.5" wide wheel will be fine on a 7-8" wide wheel?
    Racoon Twp., PA
    Might lose some tire to pavement contact, maybe.
    But they will go on
    2013 CC 5.3
    81 C10 LS1 project
    But they will go on
    How much if they are 11.5" wide?
    Racoon Twp., PA
    Hard to say, don't think it would be be much though. Just go for it.
    2013 CC 5.3
    81 C10 LS1 project
    haha imma be out over 500 bucks if your wrong
    Mar 2007
    Austin,TX
    David, there are plenty of guys running 28x11.5x16 drag radials and slicks on the stock 16x7 aluminum rims. It's not optimal, but many have done it. My next go around I'll likely be going with the 28x11.5x16 Et Streets on some stock 16x7 rims.
    Racoon Twp., PA
    well, when it comes to mud tires....
    8'' rim minimum for 12.5 wide but a 10'' rim is ideal
    But people have put 11.5 wide (285) on stock 7's with no issues
    2013 CC 5.3
    81 C10 LS1 project
