Results 1 to 10 of 15
Thread: Transgo tranny pressure ?
    Dec 2003
    Is the boost valve in the transgo kit's only purpose to raise the tranny line pressure?
    2003 Arrival Blue Silverado SS.....I just can't leave $hit alone.
    Apr 2003
    Mansfield, Texas, USA
    Not just line pressure, it raises internal case pressure.
    Your shifts too hard or something?
    Dec 2003
    yeah, the 1-2 is getting really annoying, I pretty much can't use the tow/haul because it just jerks the shit out of the truck on the shift at the higher rpms and a heavy trailer behind it.....this shift kit has brought out so much banging and clanging in my driveline that i'm considering taking it out, the only part I was considering leaving in was the boost valve if it helps get oil to the bands and such better
    Apr 2003
    Oh damn! You use the Tow/Haul with the TransGo setup you have?
    Well, why not just get you a new seperator plate?
    Enlarge all the holes BUT the 1-2 clutch feed and make the 2-3 a bit larger only. Sounds like that'd be right for your needs. It'll tone down that 1-2 shift a ton...
    With the TG setup you really don't need to use the Tow/Haul mode either. It really only bumps line pressure and raises shift points. You can always manually shift the truck yourself...
    Dec 2003
    Well I didn't use the tow/haul very long!!!! It was a little too much. Thanks for the help and suggestions, i'll try that separator plate trick out.
    Apr 2003
    Those new plates are cheap... maybe $12 or something like that and of an improved design over the OE part.
    I'll get you a link when I return home.
    Apr 2003
    Let me know how that goes. I have the same complaint as you with 0 washers and the vette servo.
    Andrew
    Andrew
    2001 Silverado 6.0 RCLB - Home Page - 4.8 to 6.0 Swap
    Nelson Tune, Comp Cam XR265HR, Pacesetters, Hotchkis Sways, 3.42, Eaton Posi, Transgo, LS1 Fans, Magnaflow, Eagle 219's 18x9.5, Fold-a-cover
    Apr 2003
    Andrew
    How big did you drill out your feed hole for the 1-2? Still on a stock trans or is it built?
    Remeber performance frictions and band will shift a lot firmer than stock too...
    If it's STILL too bad, put in a softer 1-2 accumulator spring too.
    San Marcos Texas
    I think if you have tuning done, you can lower the line pressure for normal shifts and it will still be high for WOT. You can also add some torque management under normal driving to soften the shifts.
    Dec 2003
    Originally posted by Hit Man X+Nov 12 2004, 12:18 PM--><div class='quotetop'>QUOTE(Hit Man X &#064; Nov 12 2004, 12:18 PM)</div>
    <!--QuoteBegin-yeary01z71
    Well I didn&#39;t use the tow/haul very long&#33;&#33;&#33;&#33; It was a little too much. Thanks for the help and suggestions, i&#39;ll try that separator plate trick out.
    Those new plates are cheap... maybe &#036;12 or something like that and of an improved design over the OE part.
    I&#39;ll get you a link when I return home. [/b]
    Hey man, I got your i.m., whenever my wife logs onto her user account on xp it always says i&#39;m logged on too. Stupid computers&#33; I&#39;ll probably try putting the stock accumulator springs back in.
    2003 Arrival Blue Silverado SS.....I just can&#39;t leave &#036;hit alone.
