Thread: compass temp mirror calibration
    Nov 2004
    Just bought a 2000 SilveradoLS. Has a temp/compass mirror. Truck did not come with a manual. I think the display is flakey. If i hit temp or compass, both displays come on. Each will not come on separately. Also, a little light that says "cal" comes on, and it goes trough n,s,e,w. Is it self calibrating? Any ideas, links or posts that explain user options or operation is appreciated!
    Dec 2003
    I don't think you can view just one, they both always display. As far as calibrating, i'll go check my manual and get back to you, they're not self-calibrating. The calibration options depend on what part of the country you are in. Which state do you live in?
    2003 Arrival Blue Silverado SS.....I just can't leave $hit alone.
    to calibrate it don't you just drive around and around in circles a few times?
    Aug 2004
    my manuel for my 2004 says that you can press and hold the COMP button for 8 sec. or until CAL is displayed on the mirror...and the compass can be calibrated by driving the vehicle in circles at 5mph or 8 Km/h or less until the display reads a direction.
    04 crew cab Chevy, 5.3L, Diablo Predator, Airraid MIT. K&N drop in, 3 in/out Flowmaster, 2 chamber 40 series delta flow
    Nov 2004
    yTo eary01z71- I'm in Atlanta., Thanks..
    To oh 4 4- Thanks so much....I'm in the process of getting a replacement manual.
    Again, Thanks!
    Dec 2003
    If you hold down the COMP button for three seconds and it should start cycling through numbers. Let off when it gets to 5. That is the zone Arizone is in. Then you should just have to drive in circles to get it calibrated like the others mentioned.
