Originally Posted by
RedHeartbeat
Are you talking about the cam or the oil pressure sensor? Honestly I don't know of any sensors being 2" in diameter other than the knock sensors. The cam sensor is dead center in the middle of the block behind the intake. The oil sensor is towards the drivers side of the block adjacent to the cam sensor. Your biggest issues will be getting the drive by cable throttle body wired into the drive by wire harness configuration. You have to have the IAC and TPS sensors wired into the harness correctly. It can be done but is intimidating to most novices. Its usually easier to swap for a harness that was made for the earlier engines.
