Results 1 to 8 of 8
Thread: Cost of swapping in a LS1?
    Jul 2004
    I am pretty new to the truck scene, and i was wondering how much it would cost to swap in a LS1 into a 02 Gmc Sierra. Currently i have a 4.8 and have decided on building a LS1 powered beast! I need all the help i can get thanks!
    Rick
    Jul 2004
    anyone?
    Florida
    not much, harness can be reused, mounts are fine, so no custom stuff involved. im pretty sure it can run on stock 4.8 tuning also.
    485rwhp/440rwtq SAE
    The 4.8/5.3/5.7/6.0 all are LSx style engines they use the same platform. the only real major diff. is the rod length, bore, stroke, and or aluminum vs iron
    it's an easy swap if you reuse your crank pulley, water pump, all accessories, intake, exhaust and wiring harness, pretty much leaving it a truck with an aluminum block.
    Aug 2004
    atlanta
    How much extra hp can be expected from this swap?
    Jun 2003
    North Central Arkansas, Cave City
    If you don't already have the engine the most bang for the bucks will be a supercharger or turbo system and will be a lot less work. I considered a supercharger before I swapped to an LS1 and know I would have gotten more horses that way. You will gain about 50-65 hp going from a 4.8 to 5.7.
    http://img.photobucket.com/albums/v6...nstruckls1.jpg
    05 Joe Gibbs RCSB 5 gear
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
    Aug 2004
    atlanta
    Kool Ron thanx again for all your help
