Well, to take mine off I have to unbolt the exhaust, remove the crossmember, jack up the tranny, and pull and twist like hell to work the pan out. There is a cable bracked mounted to the top of the tranny that curls around the pan that keeps the pan from dropping straight down. The valve body and such inside the pan are pretty tight around the corner with the bracket, so it doesn't give much play. The bracket has two torx-head screws on top, but I can't work a ratchet up there because of my front driveshaft. Anyone know any tricks to this? So far i've managed to cut up the boot around the linkage cable pretty good from the pan.
2003 Arrival Blue Silverado SS.....I just can't leave $hit alone.
