Results 1 to 2 of 2
Thread: 1993 Silverado 5.3 Swap questions
    Feb 2008
    Gainesville, Fl
    Hey guys
    Well i have started swaping a 06 5.3 into my 1993 silverado i got all the parts you guys told me to get. Well i got the tranny bolted to the engine and now and i just noticed the flywheel(1999-2000) bolt holes dont aline up with the torque converter.
    I was told to used a 1999-2000 6.0L flywheel to be able to use my stock transmission?? Could any one help me out? was i suppose to used a stock 5.3 flywheel?? Im really trying to solve this problem today!!
    Thanks Brandon
    P.S. When i was buying the flywheel they told me it was for an 2007 but its the same part number as a 1999-2000 flywheel is this correct?
    04 Silverado RCSB
    02 LS1 Shortblock(Stock)
    LS6 CAM - 204/219 .551/.548 117.5
    243 Heads w/ Light Weight Valves
    Exhast- LT Pacesetters w/ory, 3" Straight pipe
    Suspension- DJM 4/6, Doetsch Shocks, Caltracs
    Need a ported DBW TB > http://www.ls1truck.com/forums/sale-...ale-trade.html
    you have a flywheel spacer and longer bolts, too? If the holes are only a little off you can slot the holes to make them line up.
