So after I installed the patriot dual valve springs I started to notice that I am burning oil. It burned through about 1-2 quarts in about 1,000 miles. I made damn sure all the seals were fully seated when I put them in but it still seems like the seals would be the problem. Also, does it matter that the stock spring base and seal is all the same piece, and the spring base and seal are seperate with the patriot dual spring kit? I heard that if you do NOT put sealant on the intake rocker arm bolts that it would consume oil and I did not use any sealant on the rocker arm bolts. If it matters, I am currently running scorpion 1.8:1 roller rockers. Need help.....
