Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 55
Thread: 1BrokeC10... Motor Knock
    Oct 2005
    Baton Rouge, LA
    Ya'll know about this...
    Which led to this...
    Had to go and pick up these...
    In order to do this...
    Thanks to this nice little piece...
    I would go a bit further, and start the tear-down, but I promised my 4 yr old that I'd have Christmas lights up & around today. Plus, my 2 yr old OFFICIALLY made TWO today. Thinking about going to pick up the lil runts from day school early... since I'm off every Friday this month! WOOHOOO!!! :cheers:
    Now... for those that didn't see the video (which I thought I posted here, but don't remember), here's your quiz for this go-'round:
    What the HELL is this knocking noise?!?!?! :headscratch: I am pretty sure it's EVIDENT, but I'll post pics of suspect later. (click picture/link below)
    sounds like a bent pushrod.
    Mar 2006
    Agree it sounds like a lifter bouncing off the cam. Bent pushrod or collapsed lifter?
    Southern WI
    Bent pushrod was my first thought also.
    Mike
    2000 RCSB
    Could also be a cracked flywheel. Check the material between the bolt holes at the crank center.
    Where was the other guessing topic?
    Oct 2005
    Baton Rouge, LA
    Other topic is in Racers Lounge. Started this in mech thread cuz I will post pics of teardown, and expose culprit. ;-). Other thread was to post primarily of race times in sig.
    Not a bent pushrod. Rockers are solid. Some of posted opinions of bottom-end.
    Thanks. I like the idea of a new topic, just reminding that we already guessed LOL. I'm curious to see what the cause is too.
    Winnipeg, Manitoba, Canada
    sounds like a bottom end failure to me, keep us updated!
    Butler Ky
    Whats the oil look like?
    -Nate
    76mm Front Mount, Yank PT3200, 6.0, Built 80E, Isky 215/215, Devils Own, Nitrous Express
