I read the spec on how tight to tighten the bolts but is there any specific pattern to it?
Tired ol' 5.7, 5.3 swap in progressHandle every stressful situation like a dog.If you can't eat it or hump it.Piss on it and walk away.
Yes there is. Cant remember off the top of my head but I can get you the pattern later if someone doesn't chime in .
Ok that would be nice
See if I can do this without a picture....
10mm head bolts at the top of the head next to the intake manifold...
15mm bolts at center and bottom
15 13 11 12 14 10mm heads valley cover area
10 03 01 05 09 15mm heads in valvetrain area
07 06 02 04 08 15mm heads exhaust side of block
Go in sequence from one to ten and torque to 22 ft/lbs, second pass go an additional 90 degrees of rotation, final pass 90 degrees of rotation on all long bolts ( if you have short bolts on the ends they get only 50 degrees additional tightening ). I take a Sharpie and mark a vertical line on the top half of the head on all the bolts once I torque them to 22 ft/lbs that way I don't forget which bolts I tightened and which ones I didn't if I get distracted while torqueing the heads down. When all the 15mm head bolts are done then torque the 10mm head bolts to 22 ft/lbs.
Makes perfect since after studying it a second, Thanks!
Good rule of thumb, start in the middle and "spiral" to the outside...Of course those little head bolts go last, so there goes that rule!
1991 Silverado ECLB
LM7-T56
