just wondering, would an 85mm throttlebody bolt up and work properly with a 5.3l intake manifold
02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
professional products 85mm comes with a spacer that go from 85mm to 78mm. I'm not sure if they sell it seperate.
Yeah, it will bolt up. If you get the p p it comes with the spacer.
would a p p throttle body be much better that a stock ported one
76mm Front Mount, Yank PT3200, 6.0, Built 80E, Isky 215/215, Devils Own, Nitrous Express
Would you gain anything going to a larger diameter TB if the intake is still the same size?
2011 4x4 6.2 Silverado ltz 6" fabtech lift 20" XD spy 35" nitto mud grappler
