so i just put in a corvette servo in my truck and the 1-2 shift is horrible now because now it just slips into the next gear but the 2-3 shift is alot better any reasons why?
Sounds like you cut a seal or something.
not sure, makco transmission on the internet is where I get most of my stuff. If you can't find some I may have a few extra sets laying around my place.
After you removed the servo assembly did you pull out the spring that sits behind it? It is not held on by anything but pressure. It did the same thing to me when I did mine. When you put it back together it might not have seated correctly.
s&p headers, custom radiator with e-fans,91 sub front end with billet grill and bowtie,autometer gauges, red and grey tweed interior, dual 2.5" flowmaster super 40, Dmh cut outs, 5"-7" drop,air shocks, 20" Intro twisted vistas, gaylords bed cover
i have an extra set of seals...now that u know how to put it in ill let u pull it out and re-install it!....lemme know if you want the seals
well it just started shifting right but 1-2 is still not as firm as 2-3
well...seeing how black your fluid was i wouldnt mess with it anymore!
thats for sure
