Results 1 to 10 of 12
Thread: Thoughts please!!!
    Okeechobee, Fl
    Thoughts please!!!
    I have an 06 4.8 that i removed stock air box and put a cone air filter at the end of my mass air flow sensor. Now I'm thinking of removing intake tube and putting sensor & cone directly to intake. I already measured and it will work.Just wondering if anybody has expieremented with this?
    Jun 2004
    george west texas
    your iat's would stay to hot especially since hot weather is just around the corner...the cooler air coming from your fender well where the stock one sits right now is prolly the best place to get the cooler air
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    ff_jeff Guest
    Here is a quick rule of thumb... For every 10* drop in temperature, you get a 1% increase in power so if the temp under your hood is 170* and you are pulling in cool air out side that is 70* If your putting 230hp to the wheels you will gain approxitmatly a 23hp gain over drawing in the hot air under the hood. . and the reverse is also true... Thats why it seems like the truck runs better in cooler air than hot.
    DBYRD Guest
    1% of 230 is 2.3 just a thought but yea id keep it in stock location unless u have a hood or something to draw cold air into that locale.
    ff_jeff Guest
    Quote Originally Posted by DBYRD View Post
    1% of 230 is 2.3, but you gain 1% per 10 degree loss in temp. So If you have a cold air intake, on a sunny day at 80* and a cold day of 30* thats 50 degrees difference, so roughly 5% gain.
    Oct 2007
    connecticut
    so if im making 278rwhp on a 80 degree day, how much am i makin on a 20 degree day? i just want someone else to figure it out cuz i suck at math. i think i got somewhere around 550 at the wheels
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
    ff_jeff Guest
    If your pulling in the air from out side it would be about 294hp
    Okeechobee, Fl
    so right now i have the lid off my air box which means its also allowing alittle bit of the engine heat to get to it do you think i would be better off putting the lid back on and and cutting a whole in the bottom of the box and let it get cold air from under the truck? sorry about ?s just 16 yrs old trying to get every little bit of horses i can the cheap way
    ff_jeff Guest
    Yes... It has been proven that that mod will make you go faster... At least I know 2k5squirral and the ls1 guys do this mod.
    Okeechobee, Fl
    so your saying put top back on to get rid of engine heat
