Hey guys, hoping you can help.
I just built a forged 6.0L for an '05 GTO. BTW, this gto layed down 630+ with 10psi, procharged, l92 heads, small cam. Now it has an upgraded D1sc charger, 14psi, better cam, I can't wait to see it run.
Anyway back to the issue.
The engine has low oil pressure. Here's the situation. When the engine is first started up, it has about 38-40psi, ok kind of normal, but slightly low. When I rev the engine to 4-5K rpms when it's semi cold, I can get 60psi out of it, still kind of low.
BUT, when the engine is hot after about 20mins of driving, the engine oil pressure is 5-9psi at idle and no more than 30psi at wot. Very LOW!
Here's what I've checked:
-Made sure the rear plastic plug behind of the rear cover was there, it is and the oring is sealing.
-Made sure the front steel plug behind the timing cover was there.
-Replaced the oil pump
-When we assembled it, we were very careful about cleaning every component and pick up tube.
-The oil pump o ring was there, but replaced it when the new pump went in.
-Changed the oil and filter
-Installed an external mechanical gauge to ensure the pcm and sensor was correct, it's still hooked up
Tomorrow I'll double check the cam retaining plate just to make sure the seal is good behind that, but I'm sure it was when I put it on.
New lifters
New pump
New bearings
New valve job
New Everything!
Any other ideas you guys might have?
thanks,
allen
