Its time for radiator hoses for the 86. Does anybody know part #'s that will work? I'm running the factory radiator that came with the diesel. I hope to drive it down the driveway today!
The Corvette inspired Silverado is now rolling strong!
http://www.ls1truck.com/forums/lsx-t...silverado.html
get the rad hoses for a NBS 1 ton gas powered 6L engine.
The problem is at the radiator. The OD is 1-13/16.
measure that one at the part store. Will the stock hose get even close to the water pump? You may have to get a different rad or get creative on making a hose adapter.
I'll see what I have. It fits pretty well and angles down just like the f-body.
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
97 GMC, 2002 LS6.
i have an 87 radiator and the hoses off the donor motor.. worked out perfectly
clint
1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT and HID projectors - also for sale @ $8,500
A poor man buy's it twice
The search is not going so good. We tried every hose NAPA had and little success. I think we will be able to come up with a lower but the upper is a problem. Those big ends at the radiator are a problem. If any ideas or part #'s...chime in.
Get a gasoline engine radiator from the boneyard.![]()
I thought about that. I also thought of using one from a Camaro or truck. I used this one because
1-being a diesel it had the big radiator in it and bigger is better. Well, sometimes.
2-I already had it.
I have also had it cleaned out so I hate to trash it. Hoses should be simple stuff but thats not the case so far.
