Results 1 to 7 of 7
Thread: Should i change plugs???
    Oct 2007
    Baltimore,Md
    I have the mods in my sig with the STS,,, I still have the factory plugs in and it is tuned with those will the be a noticible difference if i went to a different plug and wire, Some people say to go one colder then stock , And if so what plus would work??? And how much difference would t be would i be able to add some more timing back in it?
    2004 silverado SS ,STS Turbo Gt-67 , TRT FMIC , Meth kit , 42lb injectors, patriot valve springs,Transgo shift kit, servos, built tranny ,e-fans and harness, e boost controller,3000 PI vigalante stall street tuned by F-body central Bret shook. needs to get on a dyno or track soon...
    Probably a set of NGK TR55 plugs if you like copper plugs and don't mind changing them every 30k or so.
    Aug 2005
    St. Anthony, Indiana
    I run NGK TR6 gapped between .030-.035
    Oct 2007
    Baltimore,Md
    what is the differnece with running a colder plug vs the stocker???
    Oct 2007
    plugs and heat: you dont want a glow plug...
    02 Sierra... motorless for now.
    02 SS.. stock bottom 4.8, 241's, 224-220/116+4, 918's and pushrods, front mount turbonetics 78mm, HKS GTII, TiAL, eBoost2, Yank PT3600, Performabuilt 60e, solid motor mounts. Tuned by me with HP Pro and LM2/AFX
    Oct 2007
    Baltimore,Md
    Quote Originally Posted by SoHo48 View Post
    huh????? if i go with a colder plug can i add more timing in what is the purpose of going with a colder plug?????
    San Marcos Texas
    The temperature of a plug means the operating temperature. If you increase the compression ratio (IE turbo, supercharger, nitrous ect.) the engine produces more heat and makes the plug get hotter than normal. If the plug gets hot enough it acts like a glow plug in a diesel and ignites the fuel air mixture before the spark does. This will cause pinging and dead pistons. I run the TR6 plugs gaped at .035.
