Ask Allen if he can get you a stroker 383 kit for that 6.oL. A 370 is I think .30 over bore on a stock 6.0L You will need a good set of Diamond pistons, Good rods, Get a stud girdle for the bottom of the block for extra strength, Your heads might need a little porting. My suggestion is 8.7 to 1 compression.
I am looking at the 383 and the 370 from Texas speed.
Good Luck,
Jamest
12 Sec. Club! SOLD
SOLD***
