Results 1 to 10 of 28
Thread: problems with fuel system
Threaded View
    Mar 2007
    Rockwall, TX
    here is what i am running: fuel cell, walbro inline 255lph, corvette filter. last week i found some water in my gas tank after the truck started running real bad after it warmed up. it would fall all over itself under acceleration after a fwe minutes of driving.
    i replaced the fuel filter, and found that when the truck started to run rough, it was because the fuel pressure was dropping to around 20. it would idle right at 60, then during acceleration, would fall to around 20, even from stop sign to stop sign in the neighborhood.
    my buddy that tuned it thought that running the water through the pump had burned it up do to the water hindering the gas's lubricating ability.
    so, yesterday, i replace the pump.
    start it up, drive it around a bit, and after warming up, it starts bogging during moderate to heavy acceleration.
    get home and put the fuel pressure gauge on it, and the damn thing is idling at almost 100psi so i havent driven it since.
    i was under the impression that the corvette fuel filter was internally regulating. my buddy that did the tune doesnt think so, and says i need to put a hi-pressure fuel regulator on the system.
    am i wrong about this filter and need to put a regulator on it? i thought after reading all of the conversion threads that this filter regulated at 58psi.
    and would having TOO MUCH pressure cause it to act almost like it did when it wasnt getting enough?
    i am about ready to just throw a carb on this thing
