Thread: LS7 cam
    Dec 2005
    Deer Creek, IL
    LS7 cam
    Has anyone had experience with swapping in an LS7 cam to an LS1 or 5.3? What are the drinving characteristics like?
    New project truck:
    '00 ECSB 4wd, 5.3, 3" body lift, gap guards, 18x9 Moto Metal 951's, 305/60/18 Mickey Thompson MTZ's
    To-do list: Built rear end, 6.0 swap with built top end, 4L80e, and a couple bottles in the bed.
    The LS7 was not designed to go on a LS1 or 5.3L... It requires wayyy higher flow rate (it needs LS7 heads) and it also needs the raised runner intake port design... Why use the LS7 cam? Why not get something that you know will work well without having to replace a bunch of parts?
    I would not be surprised if the cam doesn't have a pickup on the rear of the cam for the sensor. It's probably at the front of the engine like the LS2. Not sure but I would think it was.
    Dec 2005
    Deer Creek, IL
    I was just curious. I wasn't looking to do this, but I wasn't sure what all is interchangeable between the engines.
    New project truck:
