Results 1 to 7 of 7
Thread: Accleration cabel streched
    Irving TX
    so i went to firestone b.c my accleration cabel was too long. so i got them to get me a new one. 150 bucks later i was set. only thing was is about 2 days leter the same thing happened. i dont know wat is wrong but my cabel keeps stretching or maybe comming loose but i loose accleration cause of it. i floor it but its not doing much cause its not all the way. is there anything i could do to fix it. cause i dont want to buy another new one.
    02 chevy silverado ext. cab
    PA system; CB radio; LED underglow; LED line of fire barke light; roll-n-lock bed cover; rino spray bed liner, new center console
    SOON TO COME
    -5-7" Lift suspension/body;spin tech muffler;cai ;preformance tune;custom audio
    a stock 5.3L in a 2002 silverado cable is stretched? huh...
    was this a 4.3 to 5.3 swap?
    look there isnt enough pressure from the pedal to the throttle body to
    stretch a cable before either the pedal breaks the lil endcap off.. or
    the throttle shaft snaps into. somp'in' else is very wrong...
    airdeano
    Dec 2003
    Azle,TX
    Isnt that cable adjustable? The release for the adjustment could be slipping or you dont have it installed correctly,no way it can stretch,unless your using a really small cable
    Vortec Performance Tuned
    $150 for the installation of an $18 cable?
    My cable seemed too long in my conversion so I bent the throttle pedal rod out a little bit to take up some of the slack. Mine wasn't adjustable.
    Irving TX
    airdeano
    hey man its a 4.3L if that helps.
    and i do get ripped off by that firestone but i couldnt convince my dad to let me do it. hes like u need that to drive so let the professionals. but w.e. i dont think there is an ajuster on it either. but wat else couold be rong. it runs great jsut the pedel is loose and wobbles up and down.
    SOON TO COME
    id say your pedal/cable attaching point is bent.
    lift the pedal up, look at where the cable attaches to the pedal, if more
    than 1.00" of cable is sticking out, id rebend the pedal to remove the
    "slack". or use a universal cable terminal to remove the extra slack.
    but if there is "slack" someones got the wrong cable or the pedal assembly
    is severly tweaked...
    airdeano
    Irving TX
    how do i rebend the pedal? and wat does a cabel terminal look like? is it just a clamp to cut some of the slack down?
    SOON TO COME
