Thread: Drive line ?
    Mar 2007
    Carthage,TN
    Thumbs up
    Ok, it feels like theres slack somewhere in my driveline. I don't think my clutch is slippin, but it could be.
    also how far should your driveshaft turn before it makes the rear wheels start to turn with the truck in neutral??
    it seems like theres alot of rotational play before the rearend actually starts to move the wheels
    any help would b greatly appreciated.
    00' 4.8l 5spd, K&N intake, Granatelli M/A, Shorty headers, Hypertech prg., 160* 2/4 drop
    IF you have the G80 unit it may be getting ready to explode.
    Mar 2007
    Carthage,TN
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jul 1 2007, 09&#58;43 AM) [snapback]98267[/snapback]</div>
    its one wheel peel 3.42 gear, so if the rear end starts to go down, can it develope that kind of rotation slack im talking about ??
    Thanks for any info, SHahn
    They&#39;ve all got slack in them, just how much? U-joints wear, the transmission parking prawl has slack in it, the spider gears get slack in them, the spider gear cross shaft wears out.. You need to find out for sure where you slack is and how much. You can put a chalk line on the outside diameter of the tire with just one wheel off the ground and see how far you can roll the wheel forward and back. Be sure it is all rear end slack and not other areas.
