Thread: dont know whats going on
    Jan 2007
    my truck will start and drive but while im driving it cuts out. it has a full tank. i have no idea what can be causing it to do this. let me know if you guys have any ideas
    There's not a lot of things that can cause that other than an electical short or a clogged fuel filter/bad pump.
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Apr 2 2007, 01&#58;00 PM) [snapback]88176[/snapback]</div>
    There&#39;s not a lot of things that can cause that other than an electical short or a clogged fuel filter/bad pump.
    Yeah, check the fuel pump, fuel filter, overall fuel pressure, or the fuel injector slider. Wait, do the LS1&#39;s have the slider? I know the &#39;96-2000 5.0L and 5.7L Vortecs did...
    Jan 2007
    i have had this problem a couple times, i will start it, drive a little(maybe 10 feet) and it will like die but keeps running like on a real low rpm like its going to stall, but i just shut it off and put it back on and its fine. i think its a electrical short since it only did it on rainy days.
