Thanks,
You will need motor mount plates to adapt everything. The stock v8 mounts work tho. Yes nelson makes a great harness. Just a word of advice, if you have a 4L60E or 65E and you want to go 6.0 please get the 4L80e Transmission. Those trannys are not meant to hold against any power other then stock. Just changing to a k&n air filter puts you at risk of breaking it
You could get a flt lvl 9999 and it wont hold up. As for time. It really can't be done in a weekend. There is a lot of time involved with wiring and fitting everything in.
