			Help needed having a bracket made for my LS
					I have been searching for what I need for a year and no one makes it. (that I can find)
 The closest Ive seen is LSX innovations one thats for an LT
 What I need is a combo alt/ac/tensioner bracket that mounts on the upper passenger side.
 So the belt will go from the crank up over an idler, down and around a P pump, under the WP, up to and around a SC pulley. Got this part covered.
 Then I need it to go down to an idler, around and back up to the alt, around and back down to another idler, then towards the ac unit, around it and onto a tensioner and back to the crank.
 This will keep my ac and alt up out of the mud/water in my 4x4.
 So who can recommend someone who can make this part? Ive called the usual suspects and no one has any interest so far.
 Help!
 Thanks in advance!
- You may not post replies
- You may not edit your posts
