Results 1 to 1 of 1
Thread: Bolt Torque Specs: Dry vs Lubricated
    May 2022
    LS Head Bolt Torque Specs: Dry vs Lubricated
    Hello All,
    First time posting.
    I'm trying to find info about torqueing my LS TTY head bolts.
    I know that torqueing lubricated bolts is much less than dry bolts to acquire the same effective pre-load. I've read it can be as much as 40% depending on the lube used.
    I do see some videos with folks pouring / dipping bolts in clean engine oil while soaking the excess on a rag before install. My question is do we default the torque specs assuming a dry or lubricated fastener?
    Appreciate your opinions / feedback. Thank you.
    Scott
    Note I found:
    "Dry bolt torque requirements are approximately 30-40% higher than lubricated bolts depending on the lube. If the bolt is lubricated with SAE 30 oil - the torque compared to a dry bolt is reduced approximately 40%. Note that if torque specified for a dry bolt torque is applied to a lubricated bolt - the bolt may overload and break."
