Results 1 to 7 of 7
Thread: 96 silverado ls swap
    Feb 2018
    Does anybody have a wiring diagram of how to set up the computer...thanks
    Mar 2016
    BC Canada
    Lt1swap.com does. Thats what i used as a reference
    Feb 2018
    Quote Originally Posted by brianmcb View Post
    Thanks buddy
    Feb 2018
    Quote Originally Posted by Chip View Post
    Thanks buddy
    Brian another question did you use your old fuse block or build a new one...thanks
    Mar 2016
    BC Canada
    I used the original fuse box. Wired into the stock fuel pump relay and everything. Looks "factory" and clean
    Feb 2018
    Thanks
    Dec 2017
    I recently finished my swap on my 96 Z71 to a 07 LC9 5.3 with a Current Performance harness. My 4l60E and original fuse box and Sanden compressor. DBW Gen IV and 07 radiator and fans and made my throttle pedal bracket. Finished product looks grown there. I even used the LS coolant bottle and air cleaner box and mounted my factory storage box back where the coolant bottle was. Lots of resources here. I can send you pics if helpful. Current built a custom integrated harness that was plug and play and problem free. I rebuilt the 115K engine and stayed stock but eliminated the cylinder delete. 120hp gain in stock form, truck is a different animal. Regular driver.
