Results 1 to 7 of 7
Thread: 2004 Silverado 2500 brake question.
    Nov 2014
    Eagle River Wisconsin
    I have a 2004 2500 Silverado non hd. I'm doing the brakes on it and I'm having trouble finding the exact part number for brakes. They say you need to know if you have a 4 5/8 hub hole or a 4 7/8. Any way I can know without taking it apart and measuring? I would think I would be able to find the info somewhere but I've checked around a lot. Anyone know off the top of your head? Thanks, Dave.
    Sep 2012
    Quakertown, Pa.
    Dave, maybe you can use the RPO(regular production order) code for the brakes. The codes are listed somewhere on the vehicle. I don't know where it is located on your truck, but, older trucks had it inside the glove box. Brake codes usually have the prefix JB.
    The RPO code will tell exactly which brake system your truck was built with. When ordering parts, this code can be helpful. Good luck.
    John
    Nov 2014
    Thanks! I'll check that out. I figured there had to be an easier way than to take it apart and measure. Cheers!
    Apr 2014
    If I had to guess I would say that one will be the light duty 2500 (6 lug) and the other would be the heavy 2500 (8 lug).
    Nov 2014
    It's an 8 lug, but mine is the standard 2500 and not the HD. I bet it's pretty close to the 1500hd they made for a few years.
    Nov 2009
    SAN ANTONE
    the RPO codes are located on the glove box, open it and there is a white label that will list them all
    Nov 2014
    Cool. I'll check it out. Thanks!
