What did you use for the pcm bracket?
Used one off an s10 or a blazer. Don't recall which one but it was a 1995 and model year
Sorry. I actually got the pcm mounting bracket off It a 96 & up suburban.
Yep. Your engine space looks clean and minimalist. Not a lot of crap in there like I got. I think you have a bit more space in your engine compartment than I do.
Thanks. Once I did the swap, I went back a couple months later and cleaned up the harness and other things. I have enough room in there now if I want to turbo it
What is the box right in front of the PCM? Did the LS pcm just snap into the suburban PCM bracket?
Sorry it took a while for me to reply. The box infront of pcm is a factory storage box GM has on some trucks. I actual use it to store the original bulky LS fuse/relay holder. I have one off a 98 c1500 I will use when I have a chance to work on it again. The pcm fits perfectly in the bracket
