Well, like I said, I tried hooking the white wires together for the tach but nothing happened so I'm thinking that I might be missing a ground somewhere or I need to install that resistor. I didn't want to re thread my coolant sensor so I decided to use the 3 wire sensor from a '98 camaro LS1 (done elsewhere on here by another forum member)and that seems to be working fine. I'll have to look in to the oil pressure sensor adapter if that's the only solution. But where does the signal from the current sensor go? I don't have a wiring diagram for my current harness so I can only go off the pins going into the pcm. And yes, I do have two wires for the vss I just wasn't sure which ones to hookup.
