ok so i talked to my soon to be local dyno tuner. told him what i did and what my plans are and he gave me some advise. i told him i need to stay smog legal but was tossing the idea of a small cam around and he suggested the LS9 as it will still pass smog, sound stock, and is good for boost AND its CHEAP which is all exactly what i need.
i never really heard of the swap before but after a little searching, aparantly its somewhat common. yes there are better cams but im doing this on the cheap and need to stay legal and this is pretty much what i made my mind up on. so please dont tell me custom grind. there are so many different stories out there on what is needed for the swap and its confusing as everyones application is a little different. i think i got it down, just need confirmation and a couple questions answered..
PLEASE CONFIRM THIS IS WHAT I NEED:
1)LS9 cam
2)LS9 valve springs (not needed but recomended) GM P/N 12625033
3)2005 LS2 timing cover/cam sensor
4)Extend cam sensor harnes and swap 2 outer wires
5)1x cam gear with 3 bolts
MY QUESTIONS ARE:
1)Do I need the timing chain damper? if so, there are two... which one?
2)Can i re-use existing timing chain? (im pretty sure i can...)
3)Can i use any other timing cover from a gen 4 motor to broaden my availability or is itjust the 05 LS2 that will work?
4)Can i use my stock pushrods? (1.7 i think??)
if there is anything i missed please let me know. also, i will be doing the trunion upgrade so my stock rockers will be suitable. Thanks!
