Results 1 to 4 of 4
Thread: 6.0 with a turbo 350 trans
    Big Spring Tx
    I am new to the LSX world and was wondering if a turbo 350 or 400 trans will bolt up to a 6.0
    yes you can, there is a crank adapter that lets you do this.
    Ponca City
    Art Carr can make a converter of your stall choice so that you can use your factory flexplate.
    Slowest in Oklahoma...
    Dec 2009
    Thomasville, ga
    I got a kit from advanced adapters. came with a new flywheel the proper spacer and the bolt holes pre drilled to use a th400 in my swap.
    1984 c10-its an old truck with an LSX
