Results 1 to 6 of 6
Thread: spindle lift kits
    spindle lift kits
    was looking at getting a springtech spindle lift kit because they are almost half the price of a cst, my question is does the springtech need the UPPER BALL JOINT TAPER SLEEVE, like what the CST kit uses. just wondering if i would need to buy those seprately. also would i need extended brake lines or no.
    Aug 2004
    Magnolia, TX
    Quote Originally Posted by neilbachman View Post
    i used the sleeves but did not need ext, brake lines.
    Round Rock, Texas
    I just did a rough country 3" spindle on my 2wd and I needed extended brake lines. Russell had some issues with their quality control and I got two sets of stock length brake lines before I got the right ones. If you decide to get the lines, part # 695760 for 99-06 2wd.
    Quote Originally Posted by 2k5Squirrel View Post
    so did u have the springtech lift spindles. how well did you like them,
    Plainfield, IL
    I put a 7" fabtech lift on a 2wd with stock brake lines..
    The rear was TIGHT (I added an extra add-a-leaf to keep rake), but the front is fine (if you take off the retaining clip on the upper control arm and just run the hose straight)
    i eventually got the russell kit for stopping performance, but it wasn't NECESSARY.
    i've heard alot of bad things about any 2wd lift that changes the upper control arm. I got longer coil springs, and a new spindle, top stayed factory. 40k miles, NO PROBLEMS (except a tie rod)
    Aug 2004
    Magnolia, TX
    i liked them. had no problems with them at all. everything aligned good when i took it in.
