yep, first post.
new cam and crank sensor.
ok fellas, ease up a little.
Lets knock things out one at a time.
to make things easier for me to process, could you quote my messages, and break them down, responding to each section individually? Id appreciate it.
When you says system voltage, it would be correct for me to think that would be voltage from battery + to ground, correct?
if yes, then the cam and crank ground wires are off alot, which would mean ground correct? Im 30mi away and hes taking care of things, so he wont be able to double check the two harness grounds until later this evening.
this engine came out of a wrecked vehicle, so it ran for sure up until it ran off the road. allegedly, it was driven around the shop that my bro purchased it from.
engine is bone stock.
throttle pedal sensor is new, remember it was throwing a code for this, so it was replaced, now no codes.
id like to throw this out there again.
when he tested the four wires at the coil, one was 11.4 volts roughly, one was a ground, two were dead as a hammer with or without key on, did not test with cranking engine, should he? again, resistance from coil packs to pcm were tested and confirmed ok.
is there another way to read rpm, he just has a basic scanner tool. could he connect the multimeter, set on ohms to the rpm wire? I have no idea, just speculating?
know off the top of your head which pin signals the coils, what voltage should he see, should it be intermitant, Im guessing 5v and yes? he has the pin sheet with what is what, just wanna double check.
LSX conversions, so easy a caveman can do it.
