no actually its custom built off the basis of an mpi kit. Trey fox built it originally then I basically rebuilt it for the better.
2006 Duramax
2006 2500 6.0 work truck someday a race truck
* 2004 Chevrolet CCSB Z-71 5.3L * G80, 3.73's * Black Bear Autocal 91 oct tune * Magnaflow 3" SI/SO 14" case * Airaid M.I.T. * OEM airbox with open air modification * Color matched grille & lower valence * Blackened Tail Lights * SuperBright LEDs in brake lights & reverse lights *
In the garage to be installed: 799 heads, Dyna-Tech long tube headers, Corvette servo, 2" lowering shackles, 2wd u-bolts & bumpstops
Damn Frenchy that truk looks clean.
Never seen this many clean trucks before.
Best ET 11.54@114 w 1.52 60ft
Raceweight 4905 lbs.
[QUOTE=Frenchy;484335]
the only thing you could do to this truck to make it look any better would be get a can of black tremclad and spray the hitch
Nice looking trucks guys. Got a rattle can mixed up for mine today and sanded the spots where the paint has come off around my fender wells. Sanded it, primed it and then painted it. Turned out good, just have to do a little wet sanding to blend it in. Looks a helluva lot better than it did! Got the passenger side done today and will do the drivers side and front of the hood if it's dead at work tomorrow. I'll get some pics up this weekend once I get a coat of wax on it.
Here's a crappy cell phone pic I took tonight, still gotta clean it...
