Hmm wonder who that can be... Well last week I also found out I was 2 qts low on tranny fluid so I topped it off and its running really good. Cant wait for some 60* nights with 15+ psi. Gonna be 10s for sure. I have no doubt you'll be comfortably in the 11's. How much timing are you running?
17 degrees on 10 lbs. Its about 70 degrees and they're running pro mod at hub city tonight.
I'm running 16* with 10-12 on the street and 16 at 14psi with a couple gallons of 110 at the track. You need to see what that thing does
Were gonna try 16lbs at the truck shootout Nov 3rd. Its only 1/8 mile so I figure that would be a good time to try it.
Should move out pretty good. I plan to up the boost next time out. Hopefully it'll be a cool night. That's what I'm really waiting for. It was 90* with high humidity when I ran the 11.4 and by the last half of the track my iat's were 151 and it was only giving it 10* of timing. Still conservative but its got more in it. I'm thinking 16psi and 14-15* with some 110 in it. Should be able to break 10s with some good air. How much timing you gonna run with 16#? And what fuel?
Probably gonna run straight 110 not to sure on the timing, whatever my tuner feels comfortable with. I've got to get some factory rims and slicks. I think the th400 and higher stall is really gonna make a difference, especially when it leaves out. You leaving on boost?
With 110 I would run at least 16* no doubt. I'm running a msd 2step on the foot brake and leaving at 6psi. I did a drum swap so my rear braking isn't as good so I may have to run hydoboost to build the same boost. But with my 28x10 Hoosiers on stock rims I cut a 1.63 60' on 11psi but on 14psi I spun to the 60' and cut a 1.77. I may fool with the 2step to see if I can get it to hook better or sell my stock rims and slicks and buy some 15x10 steelies and new slicks. Ill holler at you if I decide to sell them and ill make you a good deal. I have some 325/50/15 nitto drag radials on the way for the street but may see what they will do at the track
That would be awesome , keep me posted! I been thinking about grinding down my calipers to fit 15's but I just don't like the idea of weakening my calipers .
Yea ill let you know for sure. I didn't want to grind especially bc the steelies I'm running have less clearance than bogarts so I would've prolly had to grind to the pads lol. But they are only $110 a piece
