Page 8 of 15 FirstFirst ... 6 7 8 9 10 ... LastLast
Results 71 to 80 of 149
Thread: LS6 Intake Swap
  1. #71
    Jul 2007
    Tempe, AZ
    Quote Originally Posted by Justblazin View Post
    Sorry guys i am a Noob to these trucks. Now I have a 6.0l with z06 can, lifter, rods springs. I have a RCSB. Its a 5-speed. Can I install the z06 intake and still be able to tow?
    Thanks
    Yes you can. But the truck intake will make better torque for towing.
    A.J.
    RCSB GMC SIERRA 00
  2. #72
    please delete
  3. #73
    Sep 2004
    Breaux Bridge, LA
    Quote Originally Posted by Kruznlow69 View Post
    does anyone know what you can do for the LS1 waterpump pulley to work with truck accessories? i mocked mine up with truck accessories and had to space the H20 pump pulley out about an inch. deinatly not runnable how i have it... maybe need a billet spacer to keep it centered?
    you can either pull it out some with a puller for it to line up with the rest of the accessories or pull it completly off and press the truck pulley on it.
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
  4. #74
    please delete
  5. #75
    Just Finished My Swap,thanx For The Help And Info Cajun.
  6. #76
    Since My Truck Is Cable Tb,do U Kno If The Bracket From The Camaro Would Work?or Do I Also Need The Cable?
  7. #77
    Mar 2007
    Just curious why you tapped a new hole for the valve cover vent and plugged the existing one? Also the PCV goes to the small nipple opposite the brake vacuum on the rear of the manifold, is this correct.
  8. #78
    Mar 2007
    Never mind, figured it out.
    5.3 Powered 1990 RX-7
    5.7 Powered 1988 GMC K2500
  9. #79
    houston texas
    where can i get relocation bracket or is it somethin i will have to have fabbed
    2002 silverado with a 4.3l v6 single wheel peel with true duals.......JK, 2002 silverado, KB 5.3 liter SOLD!!!(to a 16 year old for his first vehicle)
    2002 camaro z28 Fully Built LS1, ARP rod, light weight pistons, ported and polished heads, swirl polished valves, titanium retainers,comp roller cam. 85 mm tb. 300 wet shot. ratchet shifter. Bullet proof stage 3 turbo 350. lt headers. 12 bolt 342 posi.
    2008 ford f-150 6" lift 20" motometals 35.5" toyo a/t's
    2008 f450 6.4l tt king ranch cc lb dually 4x4 Bully dog Power Pup.
  10. #80
    Sep 2004
    Breaux Bridge, LA
    can either fab one up or buy a longer bolt for the idler pulley, space it out to align with the other pulleys, and place it in the very top hole for the alt and p/s bracket.
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    Knothead Racing
