Results 1 to 10 of 64
Thread: Using 2wd and slicks in a 4x4?
    Here's the deal. I want to attempt to run the truck in 2wd with a set of slicks on it, but I'm afraid that running a different size tire in the rear isn't going to play nice with the Autotrack. I don't want to be pulling the front driveshaft at the track either. Any suggestions or ideas?
    Sep 2011
    Im afraid pulling your shaft is the only option..... Lol unless you can get the same height tire up front
    Still have to find a set of 16s that clear the rear disks. I think I found a set, but ugh.
    Okeechobee, Fl
    what size slicks do you plan on running? Best option may be to get a set of stock rims and just put some cheapo tires on them for the front just to match
    49 Ford F1
    Depends what I can find. Something small like a 28 most likely.
    put slicks on all four corners.
    Jan 2011
    Mcalester,okla.
    can u just not put u truck in 2 hi and run it or will autotrack kick in when it spins
    Better start a "Let's get Justin four slicks fund"
    Quote Originally Posted by LQ9_Z71 View Post
    I've heard it screws with the autotrac.
    Jan 2011
    Mcalester,okla.
    ill check into it tomorrow justin and call u, i will look it up in my t case book, c what i can come up with
    Thanks. I also have the stabilitrac crap to deal with though.
