Look up beast sun shell on eBay and the trans go is a shift
Kit.
97 RCSB . 2WD . 5.3 . 4l60E . E-FANS . PNP 706s . TSP 228R . 3600 STALL . HD2 . VETTE SERVO . 3.73s . 2" DROP
TURBO IN THE WORKS
I saw that beast sunshell. Will that sunshell change anything or is it just a strong version of the stock sunshell? I dont wanna change the way the trans acts or anything, just make it a little tougher and i was told the stock sunshell is weak..what about this one
http://www.ebay.com/itm/Sonnax-SMART...29ef0b&vxp=mtr
Its supposed to be tougher than the beast AND addresses the planetary problem also..
That looks good and sonnax is quality stuff. The hard parts don't change anything but strength.
You should probably start a new thread so we don't jack this one any longer and you may get more/better responses.
TURBO IN THE WORKS
Well the wiring is finally cleaned up and loomed. I think it came out pretty good. The only gauge not working is my fuel gauge. I did a bunch of searching and repinned the LS PCM with the 2 necessary wires from the factory black box computer and it still isn't working. I had adjustments made in the tune and still have had no luck. If any of you have any tips for me let me know! Just wanted to share a few engine bay pics. Still have a few little things here and there I want to fix up but its 99% done. It sure is fun!
1999 Chevrolet C1500 2WD
LQ9 6.0 . PRC LS6 Heads . TR 227/239 Cam . TBSS Intake . LT Headers . 3.73 . TruTrac . E-Fans . Built 4L60E . PI 4000 Stall
There are no tips for the fuel gauge. It has to be corrected in the calibration.
Jeff
98 GMC RCSB 2wd, 100% internally stock 305, w/twin T-3 junkyard turbos,Ramjet intake w/42lb inj,12200411 PCM. 4675lbs w/me in it. Best time in 5 passes 13.01@110
You should get a NNBS intake
This is a NNBS intake. Thats why I modified the fuel rail crossover.
The NNBS and the TBSS intakes are the same thing.
