Page 6 of 7 FirstFirst ... 4 5 6 7 LastLast
Results 51 to 60 of 64
Thread: 6.0 Swap
  1. #51
    sucks about the heads. that alot of dam intake. did you mention what your doing for exhuast?
    NNBS CCSB Z71
    Lifted Exhaust Tune SLOW haha
  2. #52
    Jan 2012
    Baytown, Tx
    I am doing pacesetter lt's, ory, into a bassanni muffler.
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
    1967 Chevy II 5.3 w/ 76mm snail
  3. #53
    Jan 2012
    Baytown, Tx
    @kerrige- cracked pistons are where they connect around the crank they are not smooth but have been cracked apart. Then there are some that are smooth. If that makes sense.
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
  4. #54
    Oct 2011
    Big end of the connecting rods are 'cracked' at the foundry instead of machining to create the rod caps. This 'rough' parting surface gives more stability to the rod assembly.
  5. #55
    Jan 2012
    Baytown, Tx
    So can you run arp rod bolts or will they have to be refitted and different rod bearings?
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
  6. #56
    Oct 2011
    IMO you should be able to just replace the bolts. Just follow the recommended torque specs.
  7. #57
    Jan 2012
    Baytown, Tx
    Yeah but wih my cracked rods the bolts were fitted in the rods. They would not come out, its like they rod opening where the bolts were at were pinched to not allow them to come out. So I just sent hem back.
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
  8. #58
    Jan 2012
    Baytown, Tx
    Here are the brand new 243 heads. I think I am not gonna get the cnc work. I think This will be fun enough with out going that extra mile. I'm not tring to break any records and be the fastest truck, just a fun truck to play with. I would rather invest a set of cnc'd heads on the 66/67 Nova I plan on getting by the end of the year if not begining of next.
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
  9. #59
    Oct 2011
    Quote Originally Posted by N/ALS1 View Post
    Sure sounds like those rods were messed up! Are you getting new stock rods or stepping up to some aftermarket rods?
  10. #60
    Jan 2012
    Baytown, Tx
    Im staying with the stock rods. Are the rod bolts suppose to come out?
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
